masterloggie's avatar
Mar 26, 2020
Loose speed on LAN Connection
I have an Arris CM8200 Modem and loose speed on the ethernet connections.  Straight off the modem is 477 Mbps but off the Orbi it is 111 Mbps.  The wifi off the Orbi is 510 Mpbs. Help to get the ethe...
