masterloggie
Mar 26, 2020Tutor
Loose speed on LAN Connection
I have an Arris CM8200 Modem and loose speed on the ethernet connections. Straight off the modem is 477 Mbps but off the Orbi it is 111 Mbps. The wifi off the Orbi is 510 Mpbs. Help to get the ethe...
tomschmidt
Mar 26, 2020Virtuoso
So is LAN 3 port the one that is only giving you 100Mb/s? If so, then make sure your device and cable are both gigabit capable.
masterloggie
Mar 26, 2020Tutor
My Desktop is capable Gigabyte Z390 Designare and a Cat6 cable from the computer to the Orbi.
- FURRYe38Mar 26, 2020Guru - Experienced User
Whats connected at Port #3?
Disconnect this device then run your speed test again, might reboot the RBR to be sure.
- masterloggieMar 26, 2020Tutor
An old computer is on LAN3. I disconnected it and ran a Speedtest and no difference.
