masterloggie
Mar 26, 2020Tutor
Loose speed on LAN Connection
I have an Arris CM8200 Modem and loose speed on the ethernet connections. Straight off the modem is 477 Mbps but off the Orbi it is 111 Mbps. The wifi off the Orbi is 510 Mpbs. Help to get the ethe...
Mar 26, 2020Guru - Experienced User
Whats connected at Port #3?
Disconnect this device then run your speed test again, might reboot the RBR to be sure.
masterloggie
Mar 26, 2020Tutor
An old computer is on LAN3. I disconnected it and ran a Speedtest and no difference.
