dlinglis
Jan 27, 2017Tutor
Loosing internet connection with the Orbi
I am getting really frustrated with the Orbi system! Multiple times a day we loose communication. This is happening on the laptops (PC) as well as our iPhones. We cannot get the internet to load b...
dlinglis
Jan 31, 2017Tutor
Well, I tried a new ethernet cable and we are still having the same issue :smileysad:
Any other suggestions?
DarrenM
Feb 02, 2017Sr. NETGEAR Moderator
Hello dlinglis
You may want to try and reposition the satellite unit if it is to close to the main unit it can cause issues like drops because the devices you are using keep trying to find the best connection.
DarrenM
- VinterbirdFeb 04, 2017Star
Hi,
I have a buinch of dropouts as well, would I need to turn off my Satelite unit in a 915 square feet house? I have the Router unit in the living room where the modem is, and the Satelite in the basement below.
