dlinglis
Jan 27, 2017Tutor
Loosing internet connection with the Orbi
I am getting really frustrated with the Orbi system! Multiple times a day we loose communication. This is happening on the laptops (PC) as well as our iPhones. We cannot get the internet to load b...
Popsie
Jan 21, 2018Aspirant
Hi
I am having an issue with opening browsers when connected to my Orbi. This problem only happens on one PC running Windows 10. The PC shows as connected to the Orbi and the Internet as it is sending and receving packages of data but I cannot open any browser. The error message states that there is a DNS problem. I can connect to the internet on mobile devices and my smart TVs
If I change my connection back to the ISP connection I can immediately connect and the browsers will load
Please help!
- ajshurtsJan 21, 2018Apprentice
Popsie wrote:Hi
Please help!
What firmware version are you on? I was plagued by this issue in an earlier firmware.
- JayKCMar 28, 2018Aspirant
I am having the same issue as well. It just started today on my Windows 10 Laptop and only seems to occur in a certain area of my home when connected to a laptop dock. Did you ever find a fix for this? I just installed my Orbi system a few days ago, the firmware is up-to-date.
- FURRYe38Mar 28, 2018Guru - Experienced User
What model Orbi are you using?
Whats the Mfr and model# of the ISP modem?
Set up a IP address reservation ON the Orbi router for the Windows PC.
How far away is the PC from the Router or Satellite?
What is the distance between the Satellite and router?
JayKCwrote:I am having the same issue as well. It just started today on my Windows 10 Laptop and only seems to occur in a certain area of my home when connected to a laptop dock. Did you ever find a fix for this? I just installed my Orbi system a few days ago, the firmware is up-to-date.
Thanks for the quick response. Here are my details. I've also confirmed this is just an issue when my PC connects to my HP Laptop Docking station. If I remove the laptop from the dock, Orbi network will work. If I am connected to the dock, the Orbi network won't work, but my ISP Wifi will. I'm not sure what happened, as my laptop work working on Orbi wifi for a few days prior to this.
What model Orbi are you using? RBR20 and RBS20 (satellite)
Whats the Mfr and model# of the ISP modem? Google Fiber - GFRG210
Set up a IP address reservation ON the Orbi router for the Windows PC. Not sure what I should do here, what IP address to do I assign? Just the one it's currently connected to?
How far away is the PC from the Router or Satellite? Less than 10 feet away from router
What is the distance between the Satellite and router? Separated by a floor, maybe around 12 feet+
