dlinglis
Jan 27, 2017Tutor
Loosing internet connection with the Orbi
I am getting really frustrated with the Orbi system! Multiple times a day we loose communication. This is happening on the laptops (PC) as well as our iPhones. We cannot get the internet to load b...
linkwrt
Jan 23, 2018Guide
You can check ethernet cable with a tester, or you can use diagnostics from lan adapter.
