dlinglis
Jan 27, 2017Tutor
Loosing internet connection with the Orbi
I am getting really frustrated with the Orbi system! Multiple times a day we loose communication. This is happening on the laptops (PC) as well as our iPhones. We cannot get the internet to load b...
Mar 28, 2018Guru - Experienced User
Sounds like this docking station needs to be looked at.
Set up an ip address reservation under Advanced/Setup/LAN Setup/ADD
You can set any IP address or use one that the router has an IP address for.
Give a name for this device.
