TJ_201
Feb 27, 2020Tutor
Lose connectivity when connected to satellite
I recently have been losing connectivity when my devivices connect the satellite on my network. I only have one sateliate hub. I've tried restarting the satellite/router, modem, rebuilt the network...
- Feb 27, 2020
Well, things 'seem' to be normal. Appreicate your help. Not entirely sure what fixed things, but suspect updating the network adapter was a major contribution. The QoS on the adapter does not seem to affect things. So hopefully things are back to normal. Thank you for helping me trouble shoot things.
Another possibility was the 2nd moniter I had plugged in? After unplugging/powering the 2nd monitor, I noticed a dramatic impovement. I moved the power adapter for this monitor away and plugged the HDMI back in and things are ok..??
Feb 27, 2020Guru - Experienced User
Try the adapter with that feature disabled. If you don't notice any differences then try it with it enabled. After you have updated the adapters driver.
:smileywink:
TJ_201
Feb 27, 2020Tutor
- FURRYe38Feb 27, 2020Guru - Experienced User
Kewl. Mark your thread as solved so to let others know.
Enjoy. :smileywink:
