rxhinton
Mar 20, 2021Aspirant
Loses internet every 2 days
I have had my router almost a year now and have had no problems until now. The router loses internet connection. I reboot and it works for about 2 days, then stops again. The firmware is up to dat...
LucLot
I might have a similar problem. It was working fine until last week, and now it cuts out about once a day, including ethernet hardwired to Orbi. One thing I found is I can still access the router admin so I can just reset it from there instead of getting up, but still not a long-term solution. Another weird thing that happens for me is any website that already has a connection (ie streaming movies or Twitch) will continue to have a good connection after the computer "loses" internet. I finished a whole movie an hour after the internet went out the other day. But when I went to pick a new movie, the connection was gone. Happens on multiple devices, Android and Windows. Let me know if you find anything.
- FURRYe38Mar 20, 2021Guru - Experienced User
Is traffic meter or DST under NTP settings being used.
Try a factory reset and setup from scratch before downgrading. Don't use Traffic Meter.
What is the brand and model# of the ISP modem or ONT the RBR is connected too?
- rxhintonMar 20, 2021Aspirant
Traffic meter is being used although I never look at it. I have used 3 different modems, both experience same problem
Netgear CM700
Arris Surfboard SB6190
forgot the other one
Unfortunately I thought it was a modem problem and spent an unnecessary $200.
Ok, well someone said Traffic Meter is causing problems. I would disable it if your not really using it anyways.
There are known problems with the SB6190 modem. Something you may want to review:
rxhinton wrote:Traffic meter is being used although I never look at it. I have used 3 different modems, both experience same problem
Netgear CM700
