Bailey12
May 09, 2018Initiate
Losing connection
Purchased orbi wi 2 satlites 30-45 days ago and worked great. Returned home after 1 week and now continually losing internet connection. Modem is current and working properly. Not sure what additional...
Jeremyinsf
May 09, 2018Apprentice
Those are normal for a router exposed to the Internet. The device is doing it's job in blocking an attack that can happen regularly on direct-connected devices.
kcook111
May 09, 2018Aspirant
Thanks. Any insight into why the router keeps dropping off? Probably a myriad of possibilities but I'm close to going and purchasing a Google wifi setup.
- JeremyinsfMay 09, 2018Apprentice
Unfortunately I don't have any "good" guesses - things like that can be caused by so many different things, including firmware issues, something like a cable problem, or maybe you just have a faulty unit. I realize how frustrating things like this are, and I feel for you!
- tucsonticoMay 09, 2018Virtuoso
What firmware version are you running on both the router and satellite? Be certain they are both the same and after updating to the latest (2.1.4.10) firmware, do a factory reset and reconfigure your system manaully. DO NOT use any saved/backup config files to reconfigure your system. I know it is a PITA but this process seems to help a lot of folks with similar issues.
If you're close to being beyond the return date for the ORBI, by all means try something else. No system is perfect. Mesh-type systems have a lot of "moving" parts so be prepared to deal with that on a Google system, too. Good Luck!
- kcook111May 09, 2018Aspirant
Great suggestions...many thanks. I think I'll try the reset again but go with the manual setup like you mentioned. Definitely worth a try and not too time consuming. I'm up to date with firmware and the only option I thought may help was to double check the time settings - which were OK except I didn't have the automatically adjust for daylight savings selected.
- ibuyufoMay 10, 2018Star
I've been experiencing this loss of internet connectivity with the Orbi's satellite for a while now. It doesn't seem to matter how it's set up or which firmware you're on as you will eventually lose connectivity again. I've given the log files to the engineers for them to examine the issue and a test firmware was given to me but it did not help at all. This was a few months ago and communication gradually stopped. I'm still hopeful that they find a solution for the issue as this is a great product when it works.
