Floyddoc
Sep 15, 2017Tutor
Losing internet connection
I have had orbi system since Jan. 2017. Have been losing internet connection . Have to reset 2 or 3 times a day. I have done firmware update and reset to factory settings . Has not helped.
DarrenM
Sep 18, 2017Sr. NETGEAR Moderator
Hello Floyddoc
What firmware version are you on? are you running orbi in router mode or AP? are your bridging your modem if orbi is in router mode?
DarrenM
- FloyddocSep 18, 2017Tutor
I am running the lastest frimware. running orbi jn router mode and briding the comcast modem.
- DarrenMSep 19, 2017Sr. NETGEAR Moderator
Hello Floyddoc have you checked the modem logs to see if the modem is not having any drops of connection?
DarrenM
- FloyddocSep 19, 2017Tutor
Just checked log. I did not see any drops in connections. I enabled the MuMimo and beamforming and have not had to reset in two days. Keeping my fingers crossed. Thanks
