Tchalk
Jun 24, 2020Aspirant
losing ISP connection - after V2.5.1.16 update
My Obri system lost its connection to the ISP for no apparent reason (Comcast didn't have an outage) two days in row around the same time of day in the afternoon. Both times I have rebooted and it st...
Jun 25, 2020Guru - Experienced User
I
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
What is the distance between the router and satellite(s)?
Tchalk
Jun 25, 2020Aspirant
Thank you, Furry,
I just enabled the Beamforming and MIMO and it's now working. My outdoor office is about 40 feet from the house with a trenched ethernet cable going to the satellite back to the switch. Other than mesh wifi not working well with RING security and Yale locks, the system works great. Here's a pic of my setup... that I'm unable to upload?
- FURRYe38Jun 25, 2020Guru - Experienced User
Glad it's working better then.
- TchalkJun 27, 2020Aspirant
Thanks Furry, but... right on que yesterday afternoon (about the hottest time of day) it shut down again while both my wife and I were working from home. Again the restart fixed it. I've enabled daisy chain settings now (to see if that helps) and also just just noticing in my log reports that I'm getting a lot of Dos and ARP attacks. Maybe it's related to that too?
Are there any security setting you'd recommend short of using a VPN, worried that setting up VPN will create issues with logging into work networks?
- FURRYe38Jun 27, 2020Guru - Experienced User
You may want to check with your ISP.
Does this happen everytime at same or near same time in the day? if so, this maybe ISP related...
