Tchalk
Jun 24, 2020Aspirant
losing ISP connection - after V2.5.1.16 update
My Obri system lost its connection to the ISP for no apparent reason (Comcast didn't have an outage) two days in row around the same time of day in the afternoon. Both times I have rebooted and it st...
Tchalk
Jun 27, 2020Aspirant
Thanks Furry, but... right on que yesterday afternoon (about the hottest time of day) it shut down again while both my wife and I were working from home. Again the restart fixed it. I've enabled daisy chain settings now (to see if that helps) and also just just noticing in my log reports that I'm getting a lot of Dos and ARP attacks. Maybe it's related to that too?
Are there any security setting you'd recommend short of using a VPN, worried that setting up VPN will create issues with logging into work networks?
Jun 27, 2020Guru - Experienced User
You may want to check with your ISP.
Does this happen everytime at same or near same time in the day? if so, this maybe ISP related...
