madbrain
Jul 20, 2017Luminary
Losing satellites repeatedly
I have an Orbi AC3000 with 2 satellites (RBR50 + 2 x RBS50) for about a month. I'm running in AP mode. I have had one or both of my satellites go away completely over time. They would not come b...
ToddTodd
Jul 21, 2017Tutor
Thanks. I will give that a shot when I get a chance. It appears that this issue is blowing up in other threads. FYI, from the firmware thread, there is discussion about blocking automatic updates to prevent reversion to the broken firmware. The information there is not clear as to whether downgrading turns off auto updates or whether it is necessary to jump through additional hoops to block the bad firmware.
SkyGeneral
Aug 05, 2017Tutor
I too lost satellite connectivity. I was very frustrated and I called Netgear tech support, was put on hold for a long time, then they hang up. This happened three times then finally I got hold of a live person, I told him I was mad and I didn't want them to hang up again. They promised it wouldn't happen again. Then I was on hold for very long time (two and a half hours) then they hung up again. Cincinnati just bought the at Costco I was going to bring it back. It had been working very well for about 4 months. Before bringing it back, I tried moving one of the satellites closer to the router. I had to do a factory reset and set it up as a new system, but that worked it detected both satellites! It is now working again. Netgear tech support sucks, but I have to admit the Orbi is a pretty good system.
- SpamiltonAug 06, 2017Aspirant
I've been troubleshooting my weak signal for a week and forgot about logging in to the satellite. I am having the same issue, where the satellite receives signal, but the wifi signals from the satellite are disabled. I have done a downgrade and a factory reset. It worked temporarily, but went back to disabled. It's like the new firmware did something permanent, at least until another update comes hopefully. It also doesn't show that any devices are connected to the satellite even though I have some hardwired to it, and they work. So it seems the issue isn't receiving the signal from the router, it's that wifi devices keep dropping connection from the satellite.
- DarrenMAug 08, 2017Sr. NETGEAR Moderator
Hello Spamilton
Did you resync the satellites? also try to enable beamforming and mumimo in the advanced setup wireless settings.
DarrenM
