Enterprisemedia
Mar 14, 2019Follower
Losing wifi when internet goes offline with RBK50
Hi folks
We get a lot of internet dropouts at our place.
Our RBK50 goes totally offline when this happens. Now, of course, we don’t expect any internet connectivity when that happens, bu...
JoeM845
Mar 14, 2019Luminary
Enterprisemedia wrote:
Hi folks
Our RBK50 goes totally offline when this happens. Now, of course, we don’t expect any internet connectivity when that happens, but it takes offlone all our local devices so, for example, we cant turn smart switches on and off etc
Any advice on how to fix this issue?
TIA
I presume that you mention smart switches as an example rather than the only devices that go down. Also presume that some of these devices do not have a suspect switch between you and the device. Some smart switches may require Internet access to function or configure. I don't know. I would never buy one.
My RBK50 (AP, fw 2.1.2.210) does not behave this way. I lost Internet this AM - actually a switch between my router and the modem. The RBR50 showed the magenta top lights. I was able to connect to devices on my side of the failed switch - including most of my LAN. I did not lose communication with any device on my side of the failed switch. I power cycled the failed switch and full functionality was restored. I did not have to touch the Orbi or any other device on the network.
Note that my RBR50 is in AP mode. There are some behavioral differences that you might not expect. One could be reaction to loss of the Internet. I don't know.
ekhalil
Mar 14, 2019Master
JoeM845 wrote:
..........Note that my RBR50 is in AP mode. There are some behavioral differences that you might not expect. One could be reaction to loss of the Internet. I don't know.
The bahavior you described is the same whether Orbi is in AP or Router Modes. Loss of internet should not affect the communication between your devices that are attached to the LAN.
