Enterprisemedia
Mar 14, 2019Follower
Losing wifi when internet goes offline with RBK50
Hi folks
We get a lot of internet dropouts at our place.
Our RBK50 goes totally offline when this happens. Now, of course, we don’t expect any internet connectivity when that happens, bu...
Mar 14, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Enterprisemedia wrote:
Hi folks
Our RBK50 goes totally offline when this happens. Now, of course, we don’t expect any internet connectivity when that happens, but it takes offlone all our local devices so, for example, we cant turn smart switches on and off etc
Any advice on how to fix this issue?
TIA
