Baywatch
Oct 16, 2017Guide
Losing Wireless Connectivity
I have an Amazon Echo Dot. It has worked perfectly here for 6 months on my old wifi system. I upgraded to Orbi AC3000. The Echo Dot connects and works workd fine for a short period of time. Later I t...
Mikey94025
Oct 16, 2017Hero
Make sure your Orbi has been updated to the latest firmware: V2.0.0.74. There were many wireless improvements & fixes made.
Have you had any wireless issues with other clients? How far away is your Echo Dot far away from the Orbi or one of its satellites? Was your previous wifi system 2.4Ghz or 5Ghz? 5Ghz gives greater speed but has shorter range. Unfortunately with the Orbi the SSID is the same with both bands so it's difficult to force the Echo Dot to connect via 2.4Ghz.
- BaywatchOct 16, 2017Guide
Previous wifi was dual - but I forced it to the 2.4G. Orbi Firmware is the latest. No issues with other clients that I am aware of ... as I said, even my Echo Show works flawlessly. When I Login to Orbi I see two Amazon devices and both have an icon that suggest connected to 5GHz. I have tried the Echo DOT in multiple locations as close as 5' from the satellite. I have tried close to the Router as I didn't really want it near there ... but I can try.
- Mikey94025Oct 16, 2017Hero
OK, if the Echo Dot is the only device having issues then just confirming -- Did you go through the wireless setup again after installing your Orbi?
Some customers do not, assuming that the same SSID as their old equipment will work unchanged. Though you mentioned using your Echo Dot at other locations so I assume you have gone through the wireless setup multiple times since installing your Orbi.
- BaywatchOct 17, 2017Guide
Yes ... Echo Dot has been removed from account, factory reset, and reinstalled since Orbi. It does work ... just only for an hour or so ... maybe something to do with lease refresh? Any way to force Orbi to connect on 2.4G instead of 5G.
