us806809
Feb 18, 2018Follower
Losing Wireless Connectivity
I have at&t ISP at 50mps. I stream tv and use an iPad, that's about it. I use the Orbi system because there is one room in my house (my bedroom) that the conventional wi fi from att&t router would ...
t_k
Feb 19, 2018Luminary
us806809
A lot more digging would be required to confirm the disconnects you're seeing are the same as others have reported. However, that said, a lot of people on this forum report random, difficult to reproduce disconnects using the Orbi system. It would seem likely that you're just running into the typical "the Orbi system keeps causing disconnects" issue that is being reported.
You can see my post about the topic, which includes my experiencing chasing the frequent disconnects. You can also see the list where people are demanding refunds over the persistent issue.
Anyway, if you want to confirm if your disconnects are from the Orbi here's an easy-ish way:
The next time a device of yours is experiencing an issue where the connectivity drops, restart the farther away Orbi. If restarting the Orbi that your wifi device is not connected to resolves the issue, then it's likely that the issue is the backhaul (which is common). If that doesn't resolve the issue, it doesn't mean the Orbi's are fine, but it does mean it's unlikely you're experiencing the common backhaul issue.
idahoski
Feb 20, 2018Tutor
What is sad is I have a Smartthings smartplug connected to my satellite so I can remotely restart it due to constant wifi problems.
