chuck27p
Oct 06, 2018Aspirant
Losing Wireless Connectivity
I am having a ton of issues with the Orbi router recently. I'm not technical, so having a difficult time troubleshooting. I've had it since it came out (over a year?) without a single issue, and then...
ekhalil
Oct 07, 2018Master
Which software did you have when you didn't have issues?
I see the same issues with the current 2.2.1.210. I also had the same issues previously on 2.1.4.16.
I also saw that a roaming device usually triggers this issue, can be your daughters Chromebook roaming from one node to another.
To recover after getting this issue, it's enough to switch off the Satellite, wait until all devices connect to the Router and stabilize then switch back on the Satellite.
- ekhalilOct 07, 2018Master
Can't Netgear Support -somehow- help to collect logs from the router when this issue happens to be able to solve this issue?
It's a frequent issue that should be possible to route cause and solve! It just needs commitment from Netgear to fix this product!
