piperd
Aug 16, 2018Aspirant
Loss of connection
Have Orbi rbr and 2 satellite. Use netgearnvg599. Have had setup for while. Resent return from vacation and connection is seeming gone. Desktop is extremely slow as is mobile. If take WiFi off, use LT...
piperd
Thanks for responding. So, hardwired and using original router without Orbi, getting download of 4.9 and then a message stating “error failed to upload any data at all” Now that said, whereas wasnt before, Netflix now picks up on tv?? Reconnected to Orbi and ran again on desktop- same thing (download 6, error for upload). Netflix still works!
Christian_R
Aug 16, 2018NETGEAR Employee Retired
I would suggest contacting your ISP as you are still getting very slow speeds when you have your desktop hard wired to your ATT router. Feel free to provide an update once you're able to get in contact with your ISP.
Best regards,
Christian
