piperd
Aug 16, 2018Aspirant
Loss of connection
Have Orbi rbr and 2 satellite. Use netgearnvg599. Have had setup for while. Resent return from vacation and connection is seeming gone. Desktop is extremely slow as is mobile. If take WiFi off, use LT...
Aug 16, 2018Guru - Experienced User
Next option would be 2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
