Singularity2030
Mar 09, 2019Aspirant
Lost all LAN connections RBK50 - both router and satellites
Last night, with zero configuration changes, all LAN ports stopped functioning on both the router and satellites. I had a switch plugged in to the router so I tried bypassing it with some direct con...
Mar 09, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration.
After upgrading to v32, did you factory reset the RBR and RBS and setup from scratch?
Power OFF all devcies, router and satellite.
Have one wired PC connected to the back of the RBR. Power it ON. Do you get anything on the network adapter after the RBR comes to ready? Try the different LAN ports in back while its ON.
Besure to use a good quality known working LAN cable between RBR and PC.
Singularity2030 wrote:
Last night, with zero configuration changes, all LAN ports stopped functioning on both the router and satellites. I had a switch plugged in to the router so I tried bypassing it with some direct connections. None of them show a connection. I've rebooted a few times and even updated the firmware manually with the latest .32 version. Nothing works. I thought it was hardware failure at first but a LAN connection to the satellite stopped working too. I doubt the LAN ports on both would fail. I'm at a loss as to what it could be.
- Singularity2030Mar 09, 2019Aspirant
The modem is an AT&T UVerse Pace 5268AC. I have temporarily bypassed the switch. I tried several devices on different ports between the router and satellite, including a PC. None show a connection. I did already try disabling the satellites and rebooting. That did not make a difference.
- Chuck_MMar 09, 2019Mentor
Does the router still maintain internet connectivity via wireless?
I did not see if you tried to factory reset the RBR50 yet... if not, that would be my next step.
I do get internet connectivity via wireless. And I have done the factory reset. No change. After trying a direct connection to the router, I tried re-activating one of the satellites and I can't connect to those LAN ports either still.
- FURRYe38Mar 09, 2019Guru - Experienced User
FYI about your ISP modem:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem leaving it in router mode and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopLet us know how it goes after a factory reset.
Modem Combo Units:
Couple of options,
I've had IP Pass through configured since I got the router 6 months ago with no issues. And internet still works fine over Wireless even now.
