amys
Mar 19, 2018Aspirant
Lost connection to Samsung Smart TV and can not reconnect - unable to connect to internet
I have a CM400 Modem and Orbi AC2200 Wifi. I had no problem setting up my Samsung UN55MU6290FXZA Smart TV back in December. I was able to connect to the internet and stream media. Recently I lost my i...
Mar 20, 2018Guru - Experienced User
What channels are you uisng the Orbi router?
Try manual channel 1, 6 or 11. Any unused channels on 5ghz.
Any other wifi neighbors near by? If so, now many.
Try disabling Beamforming, MIMO, Daisy Chain and Fast Romaing under Adv/Adv Settings/Wireless
- amysMar 20, 2018AspirantThanks all. A few weeks ago I relocated my modem and router. It was only a few feet.
I moved it back to where it was and it solved the problem. I must have been out of range.
