Luisfdominguez
Jun 01, 2020Follower
lost internet at devices every 30 or 40 minutes
i have an orbi systems, a couple of days ago i updated it to firmware V2.5.1.16, but after that i lost conection from my devices every 30 o 40 minutes. o check speed and then all the devices are conn...
Jun 01, 2020Guru - Experienced User
1. What modem are you using?
2. Is it all devices? just wireless devices? Just wired devices?
3. any time theres an issue after a firmware change, a decent first step is to factory reset and re-install the setup. have you tried this?
