SirEric
Feb 21, 2019Guide
Lost listing of device after Device Name edited with double quote
Editing device list in Orbi (RBK53) running Router Firmware Version V2.2.1.210 and noticed that after updaing the Device Name for all nodes, all of my TVs went missing. I did notice an odd screen re...
Feb 21, 2019Guru - Experienced User
Remove the double "'s from the name field and see what happens. You don't have to use specific name values. They can be anything customized.
- SirEricFeb 21, 2019Guide
Thanks for the reply, and I would if I could. The issue is that the devices (all 6 TVs) no longer even appear in the list of devices, therefore I cannot edit what is not there.
After trying several searchs, and various ways to view the settings/listing, the only thought I've come up with so far is to do a factory reset and start over...
- FURRYe38Feb 21, 2019Guru - Experienced User
That would what been my next responce.
I appreiate the confirmation of there likely being no fix to this at this time, as I would suspect this is an issue in the firmware that chokes on fields containing certian special characters. It just behooves me to loose the hours of time getting the new installation finally set. At least all of the wiring, best placement, bracket installation, updating lists, etc., is done. Now to redo all of the setups and individually edit well over 100 device names/types...
Can I assume that someone will add this issue to the list of potential bugs for the firmware?
