xandiam's avatar
xandiam
Lost Orbi RBK43 power adapter
I've lost one of the Orbi RBK43 power adapters, where can I find an replacement?
Thank's!
    Thank's!
    lol how can you lose a big white adapter , they are huge
  • When traveling with some luggage it's not that hard to loose it... and the ac2200 is not as big as the ac3000 power adapter... do you know where can I find that replacement part? Thanks
  • xandiamif I was you I would contact Netgear directly to order a replacement from them, most likely they can help you with that.
  • How do I contact them? I couldn't find any email to contact their support... do you know where to find it or which is it? Thanks
