va3lim
Jan 26, 2019Aspirant
Lots of bufferings when watching TiVo recordings or live shows
Here’s my setup: I’ve a Orbi AC3000, both the RBR50 & RBS50 are connected to my TiVo modem with CAT-6 cable. The TiVo modem has a router feature which has been disabled. All devices have latest firmwa...
Jan 26, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
Try enabling the following and see: Beamforming and MIMO.
Disable Fast Roaming and IPv6.
- CrimpOnJan 26, 2019Guru - Experienced User
This is the first I have heard of a "TiVo modem." The original TiVo boxes came with a dial-up modem to connect to a phone line, but this was before internet access was common. (I believe modern TiVo's no longer include one.)
Could you be more specific about exactly what product the router and satellite are connected to and who your internet provider is?
Your iPhone and iPad are connected to the Orbi and have a strong WiFi signal and you are using the TiVo app?
Thanks
- va3limJan 26, 2019AspirantMy model of my TiVo modem/router is Technicolor DPC3848VM Docsis 3.0 Gateway. I’ve the Netgear Orbi AC3000, it has a router RBR50 & a satellite RBS50, both of them are connected to the back of DPC3848VM. Currently, the DHCP & WiFi functions of DPC3848VM have been disabled. My internet provider is Cogeco and I’m using their “Cogeco TiVo” app on my iPhone & iPad. Yes, the WiFi signal from Orbi is extremely strong (maximum bars). My house is only 2000 sq ft. The buffering issue only happened when streaming videos from TiVo & Plex. Prior to my purchase of Netgear Orbi, I do not have any buffering issues with DPC3848VM. The only reason why I purchased the Netgear Orbi is because the DPC3848VM can’t cover my whole house, some areas have weak WiFi signal. With Netgear Orbi, it covers my whole house with strong WiFi signal, but it’s not able to stream 1080p videos smoothly. Btw, I’ve about 40 devices connected to the Orbi.
- DougB628Jan 29, 2019Apprentice
va3lim wrote:
My model of my TiVo modem/router is Technicolor DPC3848VM Docsis 3.0 Gateway. I’ve the Netgear Orbi AC3000, it has a router RBR50 & a satellite RBS50, both of them are connected to the back of DPC3848VM.I think this is part of the problem - both the RBR50 and RBS50 should not be plugged into the back of the modem. The RBS50, if connected to anything, should be connected to the RBR50, if you want to use ethernet backhaul instead of wireless backhaul.
I agree with everyone else - 15 ft apart is too close - your devices are probably having a hard time deciding which Orbi to connect to as the signals are probably severely overlapping.
- va3limJan 26, 2019AspirantAll channels are currently set to Auto and security method is WPA2-PSK [AES].
The distance between RBR50 router & RBS50 satellite is about 15 ft apart.
Currently, daisy-chain topology & IPv6 are disabled. Beamforming, MU-MIMO, fast roaming are enabled.
I’m going to try disable beamforming, MU-MIMO, and fast roaming. Thanks. - va3limJan 26, 2019AspirantAll channels are currently set to Auto and security method is WPA2-PSK. I don’t think WPA2-AES is available.
I live in a subdivision, so yes, I’ve neighbors on my left, right, and back.
I’ll try your suggestion to disable beamforming. I’ll also disable UPnP. Thanks.- JoeCymruJan 27, 2019Virtuoso
Also move your satellite. 15' is pretty close. About twice that or a bit more is optimum without major obstruction.
- CrimpOnJan 27, 2019Guru - Experienced User
I forgot to ask which model of TiVo and where it is connected.
I'm also a bit confused about how the Technicolor DPC3848VM modem/router is configured. Google search turned up a reference that when this device is in bridged mode, only a single ethernet port is active. (The modem/router that I have from Spectrum is certainly that way. It has four ethernet ports on the back and when I turned off the router functions, only one ethernet port is active.)
When you look at the Orbi "Attached Devices", where does it say your iPhone/iPad and TiVo are attached (router, satellite, or wired)?
- FURRYe38Jan 27, 2019Guru - Experienced User
15 feet to TOO close. Please move them farther out as suggested by JoeCymru
I’ll try your suggestion to disable beamforming. I’ll also disable UPnP. Thanks. - va3limJan 29, 2019AspirantI’ve disabled beamforming, MU-MIMO, fast roaming and move the RBR50 & RBS50 a bit further apart (20 ft), no luck, still getting bufferings when watching movies, live shows or recordings from TiVo and Plex app.
I’ve restored the configuration of Technicolor DPC3848VM as modem/router (disconnected the Orbi devices), no more bufferings when streaming videos from TiVo & Plex apps. Thanks all for help. I’m returning the Netgear Orbi AC3000.- FURRYe38Jan 30, 2019Guru - Experienced User
Since you modem has a built in router, be sure to try one of the following if you get another Orbi system:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
