va3lim
Jan 26, 2019Aspirant
Lots of bufferings when watching TiVo recordings or live shows
Here’s my setup: I’ve a Orbi AC3000, both the RBR50 & RBS50 are connected to my TiVo modem with CAT-6 cable. The TiVo modem has a router feature which has been disabled. All devices have latest firmwa...
va3lim
All channels are currently set to Auto and security method is WPA2-PSK. I don’t think WPA2-AES is available.
I live in a subdivision, so yes, I’ve neighbors on my left, right, and back.
The distance between RBR50 router & RBS50 satellite is about 15 ft apart.
Currently, daisy-chain topology & IPv6 are disabled. Beamforming, MU-MIMO, fast roaming are enabled.
I’ll try your suggestion to disable beamforming. I’ll also disable UPnP. Thanks.
JoeCymru
Jan 27, 2019Virtuoso
Also move your satellite. 15' is pretty close. About twice that or a bit more is optimum without major obstruction.
- CrimpOnJan 27, 2019Guru - Experienced User
I forgot to ask which model of TiVo and where it is connected.
I'm also a bit confused about how the Technicolor DPC3848VM modem/router is configured. Google search turned up a reference that when this device is in bridged mode, only a single ethernet port is active. (The modem/router that I have from Spectrum is certainly that way. It has four ethernet ports on the back and when I turned off the router functions, only one ethernet port is active.)
When you look at the Orbi "Attached Devices", where does it say your iPhone/iPad and TiVo are attached (router, satellite, or wired)?
