va3lim
Jan 26, 2019Aspirant
Lots of bufferings when watching TiVo recordings or live shows
Here’s my setup: I’ve a Orbi AC3000, both the RBR50 & RBS50 are connected to my TiVo modem with CAT-6 cable. The TiVo modem has a router feature which has been disabled. All devices have latest firmwa...
Jan 29, 2019Guru - Experienced User
Beamforming and MIMO should be enabled as well. Also enable WMM.
This is probably a placement and wireles configuration issue.
Good Luck.
va3lim
Jan 30, 2019Aspirant
WMM is already enabled. Beamforming and MIMO were enabled previously but I disabled them due to someone's suggestion. Those 2 features don't make any difference when viewing streaming movies from TiVo and Plex, I still experience bufferings. Best Buy technician thinks I could have a bad Orbi and recommended me to replace it at the store.
- FURRYe38Jan 30, 2019Guru - Experienced User
Yes, possible the Orbi unit you have is faulty. Let us know if you get a replacement and how it turns out.
This users Orbi does work for him:
https://community.netgear.com/t5/Orbi/Buffering-video-when-streaming-from-NAS/m-p/1677895#M47628
