skyhawk214
Jan 16, 2021Aspirant
Lots of problems when connected to the Orbi satellite, no problems when connected to router.
My landlord installed an Orbi mesh system for the house I live in, and it's been nothing but confusing problems ever since. I'm helping to fix it, but I do not know the credentials to get to the logi...
Jan 16, 2021Guru - Experienced User
Things we'll need feedback on:
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- skyhawk214Jan 16, 2021Aspirant
- Orbi CBK40 cable modem w/ RBS satellite, w/ three wall plug extenders. Like I said, all Orbi devices.
- FURRYe38Jan 16, 2021Guru - Experienced User
Please visit and post about this over in the Orbi with cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Good Luck.
