veganchef
Aug 07, 2020Follower
Low Download Speeds
I installed the Orbi AC3000 in April 2020 and it has worked fine until recently. I would routinely get 200 Mbps download speeds. Now when I run speed tests on any of our four laptops, we're getting o...
Aug 08, 2020Guru - Experienced User
What are your wired speeds with a wired PC or laptop connected to the RBR?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
