Sanderc2
Apr 08, 2024Aspirant
Low speed XBOX series X on LAN port RBK53
Dear readers, I have an RBR50 hardwired with CAT6 to my internet provider's modem. The RBS50 is connected by wire to the RBR50. On both routers/satellites I have the full speed of 1 gig up/down and 2 ...
Apr 08, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Is IPv6 enabled or disabled on the RBR?
Do other wired devices like PCs get near 900Mpbs when connected behind the RBR?
Sanderc2
I only use CAT6 cables. Firmware is V2.7.4.24, the latest version. Ipv6 was enabled and I turned it on, with no results. Unfortunately I don't have a computer with which I can test these high speeds. It is true that the RBS, wired to RBR, transmits 1 gig via WIFI.
- FURRYe38Apr 08, 2024Guru - Experienced User
FW isn't most current:
https://www.netgear.com/support/product/rbk50#download
Orbi AC3000 Router and AC3000 Satellite
(1733+866+400Mbps)‡1733 being the wireless backhaul between the RBR and RBS only. 866 is for front haul 5Ghz. 400 is 2.4Ghz.
Game console should be ethernet connected vs wireless.
- Sanderc2Apr 08, 2024AspirantThanks for the tip! Coincidentally, an update was available and I assumed that this always happened automatically. That's why I thought that was the last version. Update was successful, but speed problem remains. Today I am going to run an extra cable to the meter cupboard so that the XBOX is connected directly to the modem. Thanks again!
Gr. Sander from The Netherlands
