aganish
Jun 25, 2019Follower
Low Speeds on 2.4 ghz
So I live in a 6000sq foot apartment, in which I had initially installed three Ubiquiti 2.4ghz AP’s LR which i had purchased back in 2013. I had a internet connection of 40MBPS then and always got in...
Fl1ntstone
Jun 25, 2019Apprentice
Hi,
I believe the issue you are seeing on 2.4Ghz, is dependent on how many streams the APs and devices support. For 1 stream, it is up to 72.2 Mbps connected speed, or about ~35Mbps max throughput. 2 streams, up to 144.4 Mbps connected speed, or about ~65Mbps max throughput.
CheerZ
