panzerbjorne
May 15, 2022Tutor
Low wired network speeds via RBS50
I have an RBR50 with 2 RBS50s running V2.7.4.24. The Sattelites are connected via wifi to the Router. I have my Macbook Air M1 and a Synology DS418play both connected to one of the RBS50s via e...
- May 16, 2022
I'm not aware of any feature to show satellite interface stats on the web admin page. Have you tried connecting your MBA and DS to your Router's Ethernets and seeing what transfer rate you get there? Also are both satellites giving the same result?
Also are you quoting speeds in mbps or mega bytes (MB) per sec? Factor of eight difference.
I wonder if the Ethernet to Ethernet transfer rate on a satellite switch fabric is somehow slugged or influenced by the maximum WiFi uplink throughout. 2.4GHz is limited to 400mbs and 5GHz to 866mbps.
May 16, 2022Guru - Experienced User
I don't use mac or have a synology so I'm not sure if there's a way in their own setting to check their port connection speed. That might be something you can play with.
but i'd test with a couple different cat 6 cables. I know you said you have cat 7 but if you have a couple cat 6 cables sitting around that are around 6ft in length, I'd try testing them. All it takes is for one of the current cables to have a sketchy connection to cause the link speed to drop.
- panzerbjorneMay 16, 2022Tutor
Thanks I'll try with some other cables too but this is my third set.
