panzerbjorne
May 15, 2022Tutor
Low wired network speeds via RBS50
I have an RBR50 with 2 RBS50s running V2.7.4.24. The Sattelites are connected via wifi to the Router. I have my Macbook Air M1 and a Synology DS418play both connected to one of the RBS50s via e...
- May 16, 2022
I'm not aware of any feature to show satellite interface stats on the web admin page. Have you tried connecting your MBA and DS to your Router's Ethernets and seeing what transfer rate you get there? Also are both satellites giving the same result?
Also are you quoting speeds in mbps or mega bytes (MB) per sec? Factor of eight difference.
I wonder if the Ethernet to Ethernet transfer rate on a satellite switch fabric is somehow slugged or influenced by the maximum WiFi uplink throughout. 2.4GHz is limited to 400mbs and 5GHz to 866mbps.
