shanem
Sep 10, 2021Aspirant
LRB20 Satellite setup
I have two Orbi LRB20 routers. Is there a way to make one of these Orbi's a satellite node to the other LRB20? So I can extend the WiFi coverage in my house? The signal on the far side is a bit weak and I'd like to repurpose the LRB20. I can't connect them via ethernet due to cement form walls, landlord doesn't want holes drilled in order to route the cable.
thanks
-shane
No RepliesBe the first to reply
