ShadowsPapa's avatar
Apr 21, 2021
LTE connection up-time Orbi LBR20
My router is NOT listed in the models! So I had to just pick one to post.  My router is the Orbi LBR20-1USNAS. It's LTE 3G/4G modem/router, etc. This may be simple - We've had tons of issues with...
  • burrington's avatar
    burrington
    Apr 22, 2021
    I really encourage you to find a better place to put the Orbi. In your case, its more important to get a good LTE signal, then make the LAN connections as required. Its better to be away from the TV which can cause interference.
    Re an external antenna: You typically can't find an antenna that has the right connector for what you want. Just buy the right antenna, and an adapter cable to match up to the Orbi. A directional antenna will work much better because it is focussed in a single direction and will provide a stronger signal from the tower with less noise from other sources. Choose an antenna that has the highest "dB Gain". The gain strengthens the signal by physical design, which makes it easier for the Orbi to work reliably.
    An omni-directional antenna will give maybe 8 to 10 dB gain, whereas a good directional antenna can give you 26 or 28 dB gain. Big difference! Here's an example: Amazon.com: Bolton Technical Long Ranger Antenna | 2021 Parabolic - Over 10 Miles Range | All Cell Bands: 5G, 4G, LTE | WiFi 2.4/5 GHz WiFi 6 | High Gain Cellular/WiFi Antenna up to +28 dB | All Carriers: Home Audio & Theater
    When you install it, put it outside and as high as you can possibly get it. Be sure to use ultra low loss coax cable. Find the tower that gives you the strongest signal and just leave it aimed there. You may have to do some experimentation to find the best location with no obstructions. Moving just a few feet can make a big difference if there are obstructions such as tall trees. With an outdoor directional antenna, high in the air, you will find the closest tower, receive a decent signal on a consistent basis, and the other towers won't matter. You won't have to be moving the antenna to different towers.
    Doing the above will cost a few dollars, but it will give you fast reliable service.
