Farjohn
Jan 30, 2022Initiate
LTE MODEM/ROUTER LBR20 external antenna connectors
I've recently purchased an Orbi LBR20 LTE Modem/Router and am totally confused about the two external antenna connectors. About half of the references I've found talk about optimizing the unit's wifi ...
Jan 31, 2022Guru - Experienced User
Those external antenna connectors seems to point to being LTE or cell phone signal antenna supporting:
https://www.netgear.com/images/datasheet/orbi/LBR20.pdf
https://www.downloads.netgear.com/files/GDC/LBR20/Orbi_LBR20_QSG_EN.pdf
So you'll need to do a search or maybe ask your cell service provider about information regarding external antennas that can be connected if the LBR is not picking up cell signals good enough using it's internal antennas.
Do a web search for SMA LTE External Antenna for products available on line.
