Farjohn
Jan 30, 2022Initiate
LTE MODEM/ROUTER LBR20 external antenna connectors
I've recently purchased an Orbi LBR20 LTE Modem/Router and am totally confused about the two external antenna connectors. About half of the references I've found talk about optimizing the unit's wifi ...
suesgirl
Feb 14, 2022Aspirant
UPDATE
I speed tested with both antennas in, one in, and none and got the best speeds with NONE. 36mbps upload and 3 download without any antennas (usually fastest in the morning, speeds will slow down as the day goes on). My upload speeds on port 1 with the antenna were 10dl and 3 ul. My unit wouldn't even work with something screwed into the second port- so don't waste your money on anything like these. Find something with MIMO and make sure you can return it- I think that's what i'm going to do.
Farjohn
Feb 14, 2022Initiate
Suesgirl, thank you for the reply. I've purchased something similar to your two discrete antennas, but it's in the form of an integrated pair (kind of like the old TV "rabbit ears") at the end of a cable with two connectors that plug into the SME ports on the ORBI. I've seen a small difference in signal strength, maybe 4dB. Two things you should be aware of; 1) In order for the ORBI's MIMO function to work, you need both antennas to be plugged in and 2) the antennas need to be cross polarized, that is, at right angles to each other, for best MIMO performance. Also, the plane of the "V" thus formed should be perpendicular to the line between the MINO antenna and the cell tower you're connected to. Since you don't know where that may be (unless you have a mobile app like "Network Cell Info" installed on a device like your smart phone) you'll need to play with direction and location of the antenna. With MIMO, it's not always all about raw signal strength. From the down and up speeds you're getting I'd guess you live in a fairly decent signal area. Here's a link to a useful You Tube video explaining some of this: MIMO vs Boosters: Do Cellular Boosters Provide the Best Signal & Data Performance? - YouTube
- suesgirlFeb 18, 2022Aspirant
Thanks for sharing!!
