Fritzjr1
Dec 21, 2017Follower
Mac address filtering
I am thinking of replacing two Linksys E2000 WiFi/Wired routers that connect to a Verizon Fios Cable Modem/router with the RB50 system. I currently keep a list of acceptable MAC addresses in the security table of the Linksys rounters as an additional security measure and just add/delete an address as needed. I didn't see this capability mentioned on the website or elsewhere. Can anyone confirm if the RB50 will allow me to continue to use this added security measure? Thanks!
1 Reply
- DarrenMSr. NETGEAR Moderator
Yes it does its located in the security settings under access control.
DarrenM
