Easton10800
Jul 16, 2020Aspirant
MAC Address
I have a mac address that continues to attemp to connect to my network which I have blocked. I believe it may be assoicated (due the similar mac address) with either the router or satellite but I ca...
CrimpOn
Jul 16, 2020Guru - Experienced User
On the Orbi web interface (http://orbilogin.net), the Attached Devices page shows the MAC address of every device connected to the Orbi, including the satellite. If the Orbi satellite is functioning, then that MAC address is probably not the satellite, which is easy to confirm.
One suggestion is to record that MAC address and look it up on one of the OUI databases, such as Wireshark:
https://www.wireshark.org/tools/oui-lookup.html
Once you know which manufacturer the MAC address is assigned to, that may provide a clue to which device this is.
- Easton10800Jul 16, 2020Aspirant
Thanks Crimpon
It is listed under the blocked devices nbot currently connected to the network, I am assuming because I blocked it?
I did go to https://www.wireshark.org/tools/oui-lookup.html and it came back as no matches.
I am a novices (pretty much) with the router
- CrimpOnJul 16, 2020Guru - Experienced User
Since it is not connected, can you post the MAC address?
I sent you a PM
