dalessit
Dec 27, 2020Tutor
MAC filtering
It looks like there used to be the ability to do MAC filtering, at least stop new MAC addresses from joining wifi. It's ridiculously easy for kids to randomize their MAC address which makes Paren...
- Dec 27, 2020
Not any more. I think it's all by IP now. Parental controls or some have installed and setup Circle:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck
Dec 27, 2020Guru - Experienced User
Good Luck
dalessit
Dec 27, 2020Tutor
Thanks,
Looks like I need to start looking for a new mesh system. Seems like a huge oversight. Kids today can easily get around these simple controls.
Also the fact I have to pay $8.00 a month for sub-par security, that is a level that pretty much all others provide for free.
- Aggie88Dec 27, 2020Apprentice
I have a RBR50 system and I can still control things by the MAC address. I go to advanced, security, and access control and can deny access or allow access for a given MAC address.
I am doing this via orbilogin on my laptop. My RBR50 system is version 1.
- dalessitDec 27, 2020Tutor
What Firmware are you using, I saw older posts say that it was replaced in later versions.
When I go to Advanced\Security\Access Control I see the following.
"To use Access Control, please use the Orbi App."I'm on V2.7.0.70
- DeanB1452Dec 27, 2020Apprentice
I just updated to 2.7.2.102 yesterday. Been using Access Control ever since I got the Orbi some 3+ years ago. It's worked on 2.7.1.60 as well as 2.7.0.70. Under Advanced\Security\Acces Control, there should be a box to "Turn on Access Control." I also have Parental Controls enabled with Circle. I just saw there is a button to upgrade to Netgear SPC but I haven't tried that yet.
