dalessit
Dec 27, 2020Tutor
MAC filtering
It looks like there used to be the ability to do MAC filtering, at least stop new MAC addresses from joining wifi. It's ridiculously easy for kids to randomize their MAC address which makes Paren...
- Dec 27, 2020
Not any more. I think it's all by IP now. Parental controls or some have installed and setup Circle:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck
DeanB1452
Dec 27, 2020Apprentice
From the web interface, Access Control allows you to block all new devices from connecting. Once you have all the devices on the network, lock it down by selecting to block new devices and then any unidentified MAC address will be denied access.
