lw187
Mar 14, 2018Guide
Mac OS and iOS Connectivity is Atrocious, HELP!
Hello all, long time lurker. Finally throwing in the towel on resolving this myself and looking for advice on my issues. ios and OS devices lose connectivity. ALL. THE. TIME. The device in question w...
st_shaw
Mar 14, 2018Master
There is no Orbi systemic problem I know of. I have no issues with Apple devices on iPhone 5 and 7+, iPad air, and two MacBook Pros.
The only issue with your settings is you should change 2.4 GHz channels to use either 1, 6, or 11. Don't use auto.
I have beamforming and MU-MIMO both set to On.
I have daisy-chain ON, but only one satellite.
Other than that, I would also go into your Apple devices and tell them to forget the Orbi WiFi network, then add the Orbi network back in.
