lw187
Mar 14, 2018Guide
Mac OS and iOS Connectivity is Atrocious, HELP!
Hello all, long time lurker. Finally throwing in the towel on resolving this myself and looking for advice on my issues. ios and OS devices lose connectivity. ALL. THE. TIME. The device in question w...
Mar 14, 2018Guru - Experienced User
Whats the Mfr and model of the ISP modem? Built in router by chance?
My setings are as follows:
2.4GHz Channel set to Auto
5.0 set to 48.
WPA2-PSK [AES]
Guest Network Disabled
NPT Set to "Use defualt NETGEAR NTP"
2.4 GHz: Enable SSID, Enable 20/40, Enable WMM, Preamble Automatic, Transmit Power 100%
5.0 GHz: Enable SSID, Enable WMM, Preamble Automatic, Transmit Power 100%
Implicit Beamforming ON
MU-MIMO OFF
Iphones, ipad, Mac Book Pro 2008, Imac 2009, Mac Mini 2012 and all other items working well for me.
lw187wrote:Hello all, long time lurker. Finally throwing in the towel on resolving this myself and looking for advice on my issues. ios and OS devices lose connectivity. ALL. THE. TIME. The device in question will show full connectivity, but will not have internet access of any kind. The situation is usually resolved on its own in time, but the reliability of the network is atrocious.
Family uses: iphone X (2), ipad pro (2), imac (late 2009), and macbook pro (early 2017). All on newest OS.
RBR50 set to AP mode. Hard wired to Verizon Fios router (which is not broadcasting its own SSIDs). The three satellites are all placed throughtout home and all have GOOD back haul status. They are not daisy chained. All devices on 2.1.2.18.
2.4GHz Channel set to AUTO
5.0 set to 48.
WPA2-PSK [AES]
Daisy Chain OFF
Implicit Beamforming OFF
MU-MIMO OFF
Fast Roaming OFF
Use a Dynamic DNS Service NO
Static Routes NONE
lw187
Mar 14, 2018Guide
thanks for the feedback all.
i'll try beamforming again.
and fyi, i used wiring in my home to set up an ethernet backhaul.
so verizon router to orbi router (AP mode) then direct connection to each satellite using cat5e wired through home.
- st_shawMar 14, 2018Master
I'm not using Ethernet backhaul on my system.
NETGEAR acknowledged issues with v2.1.2.18 and is wokring on a fix. If none of the suggestions help, you might need to downgrade to v2.0 and revert to wireless backhaul until a fix is released.
- FURRYe38Mar 16, 2018Guru - Experienced User
Let us know how it goes. I'm using Beamforming now and Wired back haul. All is working for me with my Apple devices.
lw187wrote:thanks for the feedback all.
- lw187Mar 16, 2018Guide
appreciate the input all.
i'm using a verizon g1100, for those that asked.
i don't know, could be my imagination but the wired backhaul (direct connection from each orbi satellite to orbi router) seems to have improved matters significantly
