lw187
Mar 14, 2018Guide
Mac OS and iOS Connectivity is Atrocious, HELP!
Hello all, long time lurker. Finally throwing in the towel on resolving this myself and looking for advice on my issues. ios and OS devices lose connectivity. ALL. THE. TIME. The device in question w...
lw187
Mar 14, 2018Guide
thanks for the feedback all.
i'll try beamforming again.
and fyi, i used wiring in my home to set up an ethernet backhaul.
so verizon router to orbi router (AP mode) then direct connection to each satellite using cat5e wired through home.
st_shaw
Mar 14, 2018Master
I'm not using Ethernet backhaul on my system.
NETGEAR acknowledged issues with v2.1.2.18 and is wokring on a fix. If none of the suggestions help, you might need to downgrade to v2.0 and revert to wireless backhaul until a fix is released.
