lw187
Mar 14, 2018Guide
Mac OS and iOS Connectivity is Atrocious, HELP!
Hello all, long time lurker. Finally throwing in the towel on resolving this myself and looking for advice on my issues. ios and OS devices lose connectivity. ALL. THE. TIME. The device in question w...
Mar 16, 2018Guru - Experienced User
verizon g1100 is a gateway router with wifi. Be sure to disable any wifi on this modem/router combo unit if your using the Orbi as the main host router in router mode. IF the modem doesn't support bridging, then use the modems DMZ for the IP address the Orbi router gets from the modem. This will help with double NAT condition. Or use the Orbi in AP mode if you want to use the Modem as the main host router.
lw187
Mar 16, 2018Guide
thanks for the tips.
verizon unit set to bridge mode, wifi disabled on both bands on the unit.
orbi unit set to ap
