rbraun01
Jul 12, 2020Aspirant
MAC runs slow on 5g using Orbi rbr50v2
Everything else run great with no hang up but Mini MAC runs slow using Safari for browsers. Any suggestions? Router is located 5 feet from Mac.
Jul 13, 2020Guru - Experienced User
What do you mean by runs slow? Do you mean the operation and navigation of programs on Mac is slow or browsing to web sites is slow?
What Mac Mini do you have? 2012 or newer?
What OSX version is installed?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
