ronfriedman
Jun 23, 2020Aspirant
MacBook Air gets dropped from internet by OrbiRouter RBR50
Hi: My wife has a 2 year old Macbook Air which suddenly started losing its internet connection intermittently but it happens several times a day. I use a hardwired connection and have had no simila...
Jun 25, 2020Guru - Experienced User
hat Firmware version is currently loaded?
- velaramonJun 27, 2020Guide
If you find a solution, please post it. You're not the only one having this problem.
