ronfriedman
Jun 23, 2020Aspirant
MacBook Air gets dropped from internet by OrbiRouter RBR50
Hi: My wife has a 2 year old Macbook Air which suddenly started losing its internet connection intermittently but it happens several times a day. I use a hardwired connection and have had no simila...
Aug 05, 2020Guru - Experienced User
Possible that the configuration could have changed on the ISP modem. Something you can ask the ISP about. When in bridge mode theres nothing to configure. IF the modem is still bridged, then the Orbi status page on the Advanced Tab under the internet section should report a ##.##.###.### IP address. If it reports a 192, 172 or a 10 something address, then the modem may have become unbridged.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
Yes, i know XF supports user owned modems. NGs CM1000 or 1100 would be recommended.
ronfriedman
Aug 05, 2020Aspirant
Thank you.
I checked the advanced settings on the ORBI. Under Router, the IP address is 199.xxx.xxx. Under Internet port, the IP address is 10.x.x.x. Is it correct to assume that the XF modem/router is still in bridge mode based on the above?
- FURRYe38Aug 05, 2020Guru - Experienced User
No, the 10 IP address is a private IP address, not a public address. ##.##.###.### would be seen if the modem was bridged.
This is telling us the ISP Modem is not bridged.
- ronfriedmanAug 05, 2020Aspirant
After contacting Xfinity, I am quite certain that the Xfinity box is now in bridge mode. The IP address for the Internet port now reads 98.xx.xxx.xx. Fingers crossed that this was the issue causing dropped internet connection. What do you think? If this doesnt work, I might just buy a cable modem. Thanks
Ok, glads it's re-bridged.
If something happens, then check out a NG CM1000 or 1100 cable modem.
